fender not lining up
Craigerf100
Post by Craigerf100 »
so i starded installing the fenders and im having a weird fitment problem. everything lines up well except for the top rear part of the fender. (pic below)
granted all the bolts are not all the way tighten down cause i dont have the grille on. but i cant get it to 'go in' flush against the truck.
any tips would be appreciated.
1968 F-100 Short Bed
1967 Fairlane 500 Convertable
1967 Fairlane GT/A 289ci SOLD
My Build: :fr: http://www.fordification.com/forum/view ... &sk=t&sd=a
guhfluh
Re: fender not lining up
Post by guhfluh »
NOS Ford? Repro? Tiawan? Original?
I have a similar problem with a Taiwan repro from NPD on my passenger side. It seems as if some metal needs to be cut, bent or hammered out of the way at the top lip by the cowl. Also, it seems as if the inner brace of the fender needs to be hammered down more where the bolt attaches it to the door hinge area. Those would allow it to be sucked in more.
The other problem it seems, is that the fenders have an outward bow in them at the middle above the wheel. I'm not sure that this isn't a quality of stock fenders also, but some trucks seem to have it worse than others and since I'm not a body man, I don't know how to "fix" this issue. It's more noticeable on a shiny truck as you look down the side of the truck and watch the bump bow out at each panel as it goes down the side.
'67 F-250 Crew 2wd 300ci, T-170/RTS/TOD 4-speed overdrive
'96 Dodge Ram ECLB CTD
'99 Dodge Neon ACR 2dr - 10.64@130 (Sold)
'05 Infinity G35 Sedan
Craigerf100
NOS off 2 different trucks.
Yeah looks like I'm gonna have to hammer in the brace a little where the bolt goes, like u said.
I was hoping someone had a hammer free answer :wink:
jimmy828
Post by jimmy828 »
Have you tried moving the inner fender in a little by loosening the bolts at the firewall?
Craigerf100
The bolts that connect the bracket to the fire wall?
No but the bolts that Bolt the inner fender to that bracket are still loose.
that bracket is adjustable?
dang, I already painted the fire wall lol :roll: :doh:
jimmy828
Post by jimmy828 »
Craigerf100 wrote:The bolts that connect the bracket to the fire wall?
:yt: that bracket is adjustable.
jimmy828
Post by jimmy828 »
Also i found out if you can't get the part of fender that is right under the cowl to go parallel with the cowl you can adjust the core support where it is mounted to front of frame by the use of shims. It will help by raising the fender. It worked for me.
Craigerf100
Cool, Have u had this problem? Did that fix it?
jimmy828
Post by jimmy828 »
It helped mine by moving the bracket to firewall around a little but i still have other adjustments to make . I'm not going to worry about it till spring.
