1972 ford truck auxiliary tank switch
Kentucky new guy
Post by Kentucky new guy »
I received my 1972 camper special when my father passed. I restored it about 10 years ago. I started having problems with my auxiliary tank switch in terms of getting no needle indication on the guage from either tank. My son got up under the dash a couple of years ago and I am afraid that I do not know what he did other than rearranging wires from the back of the switch. I take the truck to shows so I do not drive it much. I am at the point that I want to get the problem fixed.
I got a replacement switch from off of ebay in pretty good shape with the wiring in place through the rubber female wiring harness that plugs onto the back. I read the other posts but none of them actually answered my exact questions. The replacement switch has 6 colored wires. There are 3 black, 1 orange, one green with a red stripe, and one solid green.
In case my son did some creative wiring under there, is there anyone that can tell me where each wire goes so that I can back track them in case he changed the original wiring colors from my first switch. I will do the other things mentioned with the tank sending units etc after I get this new switch wired in properly. I also purchased a new voltage stabilizer for behind the dash from LMC truck (part# 47-0894) which I will also install after I get this new switch properly wired up. I would sure appreciate someone helping me with where the 6 wires go. Thank you in advance
fireguywtc
Re: 1972 ford truck auxiliary tank switch
Post by fireguywtc »
:wel: from Texas! :fr:
Bill
Mancar1
Post by Mancar1 »
Welcome aboard from Gerber, Ca.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
sargentrs
Post by sargentrs »
