Bumper bolt nuts
F100 Dad
Bumper bolt nuts
Post by F100 Dad »
Are there special nuts that I should use with the carriage bolts when mounting a styleside contour (sport) bumper to the rear frame brackets? :?
I am changing from a step bumper to the sport bumper and picked up a pair of rear bumper brackets but the top and bottom bumper mounting holes are square and measure 11/16" x 1 1/8"
- 1970 Sport Custom long bed, 360 C6 2WD -
sargentrs
Re: Bumper bolt nuts
Post by sargentrs »
Not to my knowledge. I just bought a new sport bumper and mtg bracket kit (thanks Brandon!) And I had the OEM step bumper. The bolts/nuts to mount the old brackets to the frame were regular type bolts and nuts. The carriage bolt nuts on both the old and new bumpers were plain nuts too. Once I got 'em broke loose, they spun off by hand. All nuts had lock washers behind them too.
F100 Dad
Post by F100 Dad »
sargentrs wrote:Not to my knowledge. I just bought a new sport bumper and mtg bracket kit (thanks Brandon!) And I had the OEM step bumper. The bolts/nuts to mount the old brackets to the frame were regular type bolts and nuts. The carriage bolt nuts on both the old and new bumpers were plain nuts too. Once I got 'em broke loose, they spun off by hand. All nuts had lock washers behind them too.
Are your carriage bolt holes in your brackets round and about 9/16"? Mine are rectangular and so big the 1/2" nuts pass right through them.
F100 Dad
Post by F100 Dad »
sargentrs
Post by sargentrs »
Shows you how the memory plays tricks as you get older. I just went to the basement and checked and yes, the slots in the bracket are the same as you said. There's a big heavy washer behind the nut. The base of the carriage head bolt is he same size as the square hole in the bumper but I guess the slots in the bracket allow for adjustment. I'll upload a pic when I get to my computer.
Edit to add pics:
F100 Dad
Post by F100 Dad »
Got it! Just use some big old washers and it should be good.
Thanks a bunch for the info and the great pics.
sargentrs
Post by sargentrs »
My pleasure! Let us see when you get it mounted. :wink:
