Enamel-clear coat
Craigerf100
Enamel-clear coat
Post by Craigerf100 »
Enamel and clear coat.
Are they the same thing?
I've been looking on the internet for some good clear coats to choose from, and I keep finding affordable enamels.
Difference?
Ill be painting my truck jet black,
Should I spray on A coat or 2 of clear coat?
Any advice appreciated
1968 F-100 Short Bed
1967 Fairlane 500 Convertable
1967 Fairlane GT/A 289ci SOLD
My Build: :fr: http://www.fordification.com/forum/view ... &sk=t&sd=a
jimmy828
Re: Enamel-clear coat
Post by jimmy828 »
Depends on if you are using basecoat/clearcoat or using single stage. The advice I was given before i started my paint job made since to me. It was that if i had never painted a car before it was best to stay away from basecoat/clearcoat. That type of paint was not easy to fix if i was to screw up.I guess it is for the more experienced painters. I went with the single stage urethane and i'm glad i did. I got some flaws that need some attention and can be fixed easily since i am using single stage. trust me, i'm no auto painter at all but i know what would work best for me and it turned out really well.
Craigerf100
Single stage?
jimmy828
Post by jimmy828 »
Craigerf100 wrote:Single stage?
you don't have to use clear coat over a single stage paint. It will come to a glossy shine when paint goes on. I sprayed 3 coats on and waited about a week for it to cure and then wet sanded and buffed. Here's a pic before wet sanding to get rid of orange peel.
Craigerf100
okay cool thanks for the info :fr:
