Rear Bumper Ideas
jerrryhumpjr
Rear Bumper Ideas
Post by jerrryhumpjr »
Will a rear sport bumper off of a 61-63 fit on a flareside bump? Just looking at pics, the mounting looks very close. Can't find dimensions on the 61-63 bumper. Suggestions? :?
"Time, patience and perserverance will accomplish all things." - unknown
colnago
Re: Rear Bumper Ideas
Post by colnago »
Check the LMC or NPD catalogs. If they have the same bumper part number for 61 - 72, then you're good to go. If they're different, then it's probably because the frame dimensions or body shape changed. Either that, or take a tape measure to your local junk yard.
Joseph
jerrryhumpjr
The bumper for all 57-72 flaresides is the same. I am looking at the unibody/styleside shaped bumper. I found out on another site that it will fit. There is nothing to measure in the scrapyards around here, and no one shows dimensions. Most of the bumps have either been kept or crushed. :( Thanks for the feedback. :fr:
