Who has repaired rusted kickpanels?
guhfluh
Post by guhfluh »
I know the kickpanels are a common rust through area in these trucks because of the debris that collects behind there in the fenderwell area, but I haven't been able to find more than one picture of someone repairing them.
Mine are both rusted through pretty bad, as well as a small hole in the passenger floorboard. My problem is that I don't know how to weld and don't have a welding machine. I'm very close to buying a Lincoln 140 just for this truck and teaching myself how to weld, but that's in the future.
Anyone have any experiences, suggestions or especially pictures of your kickpanels repairs?
'67 F-250 Crew 2wd 300ci, T-170/RTS/TOD 4-speed overdrive
'96 Dodge Ram ECLB CTD
'99 Dodge Neon ACR 2dr - 10.64@130 (Sold)
'05 Infinity G35 Sedan
cep62
Re: Who has repaired rusted kickpanels?
Post by cep62 »
Well if you have the ambition to learn, I'd buy the equipment and learn to use it. :2cents:
or take that money and pay someone else. :hmm:
67nukeford
Post by 67nukeford »
I'm in the process of doing this. I've got my cab off of the truck, and I'm removing the panels that enclose the vents on the cab sides. Eventually, I'll be removing the cowl, also. But, the drivers side kick panel is in pretty bad shape. the back side is badly rusted, and it has rusted through at the bottom. My plan is to clean up as much of the rust as possible, then start replacing the sheet metal. This might be tough to do without going as far as I am, depends on where/ how bad the rust is in your kick panels. I'll see if I have some pics of what I have on the backside, and post them up tomorrow.
Pat 1967 F100 4WD
LINK TO PROJECT THREAD
:http://www.fordification.com/forum/view ... &sk=t&sd=a
guhfluh
Post by guhfluh »
My floor pans are fine, except right where they meet the kickpanels. On the pass side I have two pinholes there. The kickpanels have fairly big holes, but only right at the bottom where they meet the floor. My truck is kinda strange how localized the rust is. I would have thought the kickpanels would have rusted through from the vents being 6" full of rat nests and years of rotting, wet plant debris built up in there, but that area is fine, as are the rest of the floor pans.
I am contemplating a poorly done patch job with sheetmetal screws and body seam caulk, until I can get it welded up right and painted, I just hate doing it halfassed, but I need the holes filled to plug the water leaks now.
I'll take some pics of the current state and post them so you can see.
67nukeford
That whole area down there is a pain, since 3 panels are welded togther (rocker, floor, kick panel). I had to rebuild the front of the rocker on the drivers side, and the bracket to hold the nut that attaches the fender. I wish I could have found a better cab, but most of them here are in evern worse shape!
Pat 1967 F100 4WD
guhfluh
Post by guhfluh »
jimmy828
Post by jimmy828 »
cep62 wrote:Well if you have the ambition to learn, I'd buy the equipment and learn to use it. :2cents:
That's what i done . Purchased myself a welder and learn enough about it to replace certain areas in truck. The kick panels was the first thing.
undertakerman
Post by undertakerman »
I have just replaced the passenger side kickpanel from the vent down, the lower corner of the firewall and part of the floorpan. The photo of the kickpanel shows the work involved in replacing it. And the other photo shows the final mock up before prep and installation including the floor panel. The other photo shows the firewall repair along with the panel gutter replacement trim and final mock up before final prep and installation. Every piece except for the floorpan had to fabricated. When everything is complete I will post photos so you can see how it turned out. Hope these photos help you see what you will need to do. I did what others have say. Buy yourself a Lincoln Mig Welder, a 4 foot square piece of 18 gauge, snipes and a hand shear made to cut 18 gauge and teach yourself how to cut and weld. I did it 11 years ago and I'm still learning. Good luck with your project. :thup: :thup: :thup:
You know man can live alone, but he cannot live without Peanut Butter and Grape Jelly.
Whateverman
Post by Whateverman »
good reason to buy a welder and learn to weld...its the same reason i decided to learn to weld ..and became a welder.
before that happened i did a self drilling screw, rivet and (marine)caulking repair with a couple of chunks of tin from an old fridge door which held up fine until the floor rotted away
as previously stated there are 3 layers of sheetmetal in the floor in that area..its a pain in the butt regardless of whether you weld in new metal or screw/rivet it together (get ready to break some drill bits)
you'll find that the rust in the floor section actually extends much further than you would expect (anywhere from 2 to 8" in the 4 cabs i've done)...buy or borrow a chipping hammer and do some smacking around on the floor with the pointy end --its pretty shocking sometimes...be prepared to do some floor pan repair as well
goodluck!
67nukeford
Bought a bead rolloer from Eastwood, to make that little flange on the kick panel patch, where it spot welds to the door frame. Came out perfect!
Pat 1967 F100 4WD
67nukeford
Here is what I ended up patching....
Pat 1967 F100 4WD
67nukeford
Drivers side is in
Pat 1967 F100 4WD
guhfluh
Post by guhfluh »
Thanks for the pics guys!
Ftruck Fan
Post by Ftruck Fan »
Did you guys remove the cowling before attempting this repair or just take off the fender? :? :fr:
lloyd399
Post by lloyd399 »
subscribed
