Hello fortification nation! I have a 1969 F100 360 v8. Truck was running great and started every time no problems. The only issue I had was I couldn't get the brake lights or rear signal lights to work. All other lights were functioning properly. Then last weekend I put a trailer on the back of the truck, drove it to a stone place, loaded the trailer with a yard of decomposed granite and when I turned the key I got nothing. So I tried to jump it, didn't work. We put a new solenoid in it, no luck. Put a new starter on her, nothing. Checked the battery, it read as a bad battery so I got a new battery, put it in and still nothing, there is no response to the turn of the key at all. Any ideas???
Thanks!
Truck won't start
- fireguywtc
Re: Truck won't start
from Texas!
Bill
- Mancar1
welcome aboard from Northern Ca. If you post your ? in Electrical or Engine section I am sure u will get some good answers.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
- 1970FordTK
Welcome from North Carolina.
from Georgia!
from Massachusetts.
- tbone6
- conn72ford
it might be the ignition itself, theyre like 20 bucks ar O'riely's. I had a similar problem with my truck and that was the sole casue of it
'72 F250 4x4 390, NP435, 4" lift, 35" trail diggers, 60's Ford police spotlight, no rust
