How is cab mount bushing hardware designed to function?
sargentrs
Post by sargentrs »
What I mean is, how is it supposed to work? I have 3 out 4 sets of my cab mount hardware and have to make my own final set. I have access to a full fabrication shop so tools and materials are not an issue. From looking at the originals, I'm a little vague about the form, fit and function. There are some tabs on the inner tube that look like they either lock it into the outer tube or keep them separated a set distance. So are they supposed to keep the spacing between the upper and lower washers a set distance or just hold the bushings centered and tighten to the specified torque? I'll be installing some polyurethane cab and radiator support mounts which require the use of the original mounting hardware so I want to, as closely as possible, mimic the function of the original. If they are to hold a set distance, then torque, I need to make sure the lengths of the inner and outer tubes meet to hold that distance. If just centered and torqued, allowing a 1/2" or so difference in length would be sufficient. Anybody got a clue?
stephen44
Re: How is cab mount bushing hardware designed to function?
Post by stephen44 »
IIRC - the two rubber halves are made with a groove so the locate in each other - so they can't slide laterally - they also have a ridge to locate them into the frame hole.
through the center is a metal tube - which limits the compression when tightening down and gives it rigidity.
if you look here - it will give you a good guide to constuction
http://www.ebay.com/itm/Prothane-6-110- ... 74&vxp=mtr
or from lmc
thanks
Stephen
sargentrs
Post by sargentrs »
So the outer tube is what limits the compression and therefore the only important dimension, besides the diameter of the tube of course, is the length of the outer tube. Correct? I measured this at 2-5/16".
stephen44
Post by stephen44 »
I think I have an old set down in the shed - I'll have a look in the morning and post the dimensions if I have them
thanks
Stephen
sargentrs
Post by sargentrs »
Unless you want to part with one piece for a nominal fee? :D I already have the other three so I have the dimensions.
stephen44
Post by stephen44 »
If I find it - you can have it - do you just need the metal tube ? - or the rubbers as well ?
thanks
Stephen
sargentrs
Post by sargentrs »
Just the metal tubes. Thanks! Just let me know shipping and I'll take care of you :wink:
stephen44
Post by stephen44 »
I've found them - they are the original ones - the rubbers are ok - but the tubes are a bit rusted and thin - the ends especially ?
I can get some photo's of them if you want - or I can just put them in a PO flat price box and send them on a ride for you ?
thanks
Stephen
sargentrs
Post by sargentrs »
I'll take 'em as is. Just let me know what I owe you for the ride. Thanks!
stephen44
Post by stephen44 »
sargentrs wrote:I'll take 'em as is. Just let me know what I owe you for the ride. Thanks!
PM me your address
thanks
Stephen
sargentrs
Post by sargentrs »
Address is in your box. Thanks!
PetesPonies
Post by PetesPonies »
Looks good pinch and seems like it will be better than stock. Good job.
Pete's Ponies
Mustang RUSToration & Performance
