ford throttle linkage 300
gregamorton
Post by gregamorton »
guys on my 1971 crewcab i swapped in a 300 and missing pieces from factory throttle linkage. I have the two throttle rods and the swivel base. There seams to be a threaded rod that must go in and bolt to intake or somewhere to keep swivel part stationary. I need help with parts or if there is a pic of factory setup to go by. Thanks for help in advance!
1967 mercury F350 7.3 IDI ats turbo kit c6 gear vendor overdrive 3.73s rolling on 19.5s
1971 sport custom on 1979 f350 highboy frame 460 c6 np205 dana 60s 3.54s
1974 F100 baby blue & rust 240 3 speed 3.70s sitting on the ground!
1990 F250 extended cab FI460 e40d 3.55s daily driver
Possibly looking for my next bump right now!
rmurphy
Re: ford throttle linkage 300
Post by rmurphy »
Let me look I may have it. If it's what I think, there's a rod and bracket that bolts to the firewall.
gregamorton
yea it that part. I was just thinking about welding up the triangular part so it wont move and that would work. cant figure out why they would do it this way unless it can bind up some how!
gregamorton
sir I went and looked at my firewall and there is no factory holes so I will weld my piece up to make work. Thanks for checking on it for me though,
