Thanks. I hope it looks good when on the truck. I am figuring it will add to the fender scoops look up front along with the bumper mods when I get the bumper finished.BobbyFord wrote:Ahh, I see what you're doing now. I couldn't figure it out in my head. Looks good!
Building a cowl induction hood look
- elgemcdlf
Re: Building a cowl induction hood look
- fbomb100
I like it .. can't wait to see it on the truck!!
- 1967AceStroker
That's gonna look sweet when your done with it. Might as well smooth the hood seam while your at it. You'll already have half of it done by the time you stitch up that front.
My Project Thread (Not updated in years.)
1967 F-100, Shortbed, 351W - 72mm Single Turbo - Megasquirt MS3x Engine Management, Tremec TKO 500, Ford 9" - Strange Nodular Center Section - Strange 35 Spline Axles - Strange Full Spool - Caltracs - DJM Drop Kit, Crown Vic IFS Swapped - 2 Coils Cut, Power Steering, Power 4 Wheel Disc Brakes, Paint - Kona Blue
- elgemcdlf
The hood is on the truck. We are in the process of moving to southern MO & the cable to put pics is in MO while I am currently in IN until Monday. The tacks across the front are coming all the way out to maintain the original seam across the front. When I get a chance I will post pics.
- HIO Silver
Personally, I'd also fill it in but I already asked about that... the goal is to make it look factory so the hood seam is apparently staying.1967AceStroker wrote:That's gonna look sweet when your done with it. Might as well smooth the hood seam while your at it. You'll already have half of it done by the time you stitch up that front.
- fbomb100
LOL ahh what a tease.. can't wait to see nowelgemcdlf wrote:The hood is on the truck. We are in the process of moving to southern MO & the cable to put pics is in MO while I am currently in IN until Monday. The tacks across the front are coming all the way out to maintain the original seam across the front. When I get a chance I will post pics.
well move safely to your new home
How far will it stick up past the cowl?
Taylor-
1968 F250 Highboy np435 dana 24 4.10's
- elgemcdlf
It's only 3/4" above the cowl. It is a subtle modification but the concept could be used for a taller hood if someone wanted. We are in MO & unpacking everything. Once we get to a good point I will post pics of it on the truck.
where abouts in MO did you move to?elgemcdlf wrote:It's only 3/4" above the cowl. It is a subtle modification but the concept could be used for a taller hood if someone wanted. We are in MO & unpacking everything. Once we get to a good point I will post pics of it on the truck.
60 Mercury Comet
65 Ford Econoline
77 Ford F250 "lowboy" 4x4
09 Harley Xl1200c
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
- colnago
Any updates???
Joseph
![Worthless without pics :nopix:](./images/smilies/icon_worthless.gif)
Joseph
- jthulan
I hope your move went smooth and you are still able to work on your truck?elgemcdlf wrote:It's only 3/4" above the cowl. It is a subtle modification but the concept could be used for a taller hood if someone wanted. We are in MO & unpacking everything. Once we get to a good point I will post pics of it on the truck.
1971 F100 Custom, 119,xxx miles
1984 Chevy Silverado, 437,xxx miles, original owner
1976 Ford Ranchero GT, 130,xxx miles
2015 Volvo XC60R, 60,xxx miles, daily
- 67nukeford
I can't wait to see this on the truck!!
- 67nukeford
I soo want to see pics of this on the truck!
- elgemcdlf
We are in Alton, MO. About mid-state about 20 miles from the Arkansas line.FordTruck wrote:where abouts in MO did you move to?elgemcdlf wrote:It's only 3/4" above the cowl. It is a subtle modification but the concept could be used for a taller hood if someone wanted. We are in MO & unpacking everything. Once we get to a good point I will post pics of it on the truck.
- elgemcdlf
Well here are some pics of the hood as it stands. It still needs finish work done so this is raw form. I am planning on making the Fordification show in Anderson, MO so anyone there can get a much closer look.
![Image](http://www.fordification.com/galleries/albums/userpics/11892/005_-_Copy_%282%29%7E1.JPG)
![Image](http://www.fordification.com/galleries/albums/userpics/11892/006_-_Copy_%282%29%7E1.JPG)
![Image](http://www.fordification.com/galleries/albums/userpics/11892/007_-_Copy_%282%29%7E0.JPG)
![Image](http://www.fordification.com/galleries/albums/userpics/11892/008_-_Copy_%282%29%7E0.JPG)
![Image](http://www.fordification.com/galleries/albums/userpics/11892/009_-_Copy_%282%29.JPG)
When the truck is finished it will have 3/16"-1/4" gaps on all panels.
