I have a 71 F250 4x4 i plan on putting a 390 in, i was told the 2wd oil pan wont work,could someone share there vast knowledge on this ??
If this is true then what i need is a oil pan and pickup tube for a 390 4x4 !!
Thanks to any and all help..
390 oil pan for a 4x4
- jamesingarage
Re: 390 oil pan for a 4x4
PM Sent
You will also need the studed main bolt to bolt the pick-up tube for a rear sump.
- jamesingarage
Thanks for the info, I did find this out the other day,I thought i knew alot about these old trucks, but you can teach a old dog..hazelnut wrote:You will also need the studed main bolt to bolt the pick-up tube for a rear sump.
