HVLP paint gun
ccford
HVLP paint gun
Post by ccford »
I'm painting a truck (69 F100) for the first time and have a few questions for the body work guys...
1 - What is difference/benefit of the high dollar HVLP guns vs. the low end guns. It looks like you can spend 25 - 200 or so and I can't tell the difference between them. I'm leaning towards a hot rod flatz paint. http://www.tcpglobal.com/Customshop/ksflatz.aspx
2 - What advice can anyone offer to stop the rust in the seam of the running down the bed. I've sand blasted it out and gone over it with a wire brush. It was fairly bad. There's a few places where it has rusted through (small holes). I'm planning to use rust encapsulator, but want to do anything else I can to prevent it from showing up again.
3 - What is the sealer material / filler stuff in the rain gutter? Also seems to have been in the bed seam at one point.
Thanks in advance for any advice you can offer
Dirty Offio
Re: HVLP paint gun
Post by Dirty Offio »
I hope someone else has a good answer for the filler on the body seam...I want to know too!
BUT, on the paint guns I can help.
The cheaper (older design) paint guns are LVHP guns. (Low Volume High Pressure) They move a small amount of paint at a time using ALOT of air. (compared to HVLP)
HVLP is High Volume, Low Pressure. It is a newer (not new, but newer) technology. It uses alot less air pressure and moves more paint in comparison.
Pros:
HVLP: ALOT less overspray, and a good painter with one can usually paint faster.
LVHP: Easier to use, less likely to get sags and runs. More likely to orange peel.
CONS:
HVLP: It moves alot of paint, so until you get the hang of it you will probably sag and run your paint, worse than using LVHP.
LVHP: Lots and lots of overspray. No matter what you use, overspray is always a problem. It is worse with the older guns.
No matter which you decide to go with, find a refrigerator box or some scrap body panels to practice on until you get a fairly smooth technique down. If you still have sags or runs or orange peel, no worries, that is all fixable, it just takes time.
When in doubt, hit the gas. It may not be the right answer, but at least it ends the suspense!!
The only substitute for Cubic Inches, is Cubic Money!
1967 F-100 swb "Varmit"
1968 F-250 4dr lwb "Beast"
1976 F-350 drw 460
1977 Club Wagon
1986 F-250 lwb
BobbyFord
Re: HVLP paint gun
Post by BobbyFord »
Use 3M seam sealer. Do not use the water-based seam sealers as those shrink over time, creating cracks for moisture to get into.
http://3mcollision.com/3m-fast-n-firm-s ... 08505.html
http://3mcollision.com/3m-ultrapro-auto ... 08300.html
bjde0b
Re: HVLP paint gun
Post by bjde0b »
I used lord fusor seal sealer.
chad67
Re: HVLP paint gun
Post by chad67 »
I used a HVLP gun for the first time this past summer. I thought it was very easy to use and didn't have any issues with runs at all. The best part is-I tried it because my buddy was using them and I found a coupon in Hot Rod magazine to get one from Harbor Freight for $9.99! I was skeptical, but found the results to be excellent. The paint cup is 20 ounces, but I mixed my paint a quart at a time to refill the gun. My flat black came out uniform.
1967 F100 SWB
chad67
Re: HVLP paint gun
Post by chad67 »
Here's the bed side I painted, turned out pretty well.
1967 F100 SWB
ccford
Re: HVLP paint gun
Post by ccford »
Looks good. Any rust coming through the seam? I'm still debating on whether or not to weld mine shut.
chad67
Re: HVLP paint gun
Post by chad67 »
No, but it hasn't been on long. I cleaned the seam out to bare metal and laid on a coat of flat black. Once I have all the body work done on the whole truck and everything is sprayed-I'll put the seam sealer in and spray the whole truck over at one time. So, right now I am using the black as a primer since the truck has to sit outside.
1967 F100 SWB
