71 Ranger XLT Steering Column needed
Corkwheats
Post by Corkwheats »
I'm looking for a steering column for my 71 Ford Ranger XLT.
Automatic Transmission.
I'd like to find a set up complete from the steering wheel down to the coupling hook up under the hood. I've never pulled/installed one before, but it looks like that would be the easiest way to go.
Thanks,
Bob
71 Ranger XLT LB 2WD
Tilt Steering, West Coast Mirrors
390, 9.5-1 C.R., Holley 600, D2 Heads, C-6
Custom Grind Oregon Cam
Flotech Headers, 2.5" Duals w/H-Pipe
basketcase0302
Re: 71 Ranger XLT Steering Column needed
Post by basketcase0302 »
Bob,
Tilt steering is one of the easiest upgrades we can do to our trucks-highly recommended. Here's a Bronco column that I know would bolt into the cab-but I'm not sure if the overall length would be different than the truck column? You'll also never see on for this price again-I believe he listed it funny so it doesn't show up for a lot of folks?
http://www.ebay.com/itm/150951852927?ss ... 1423.l2649
And here's the tilt steering tutorial:
http://www.fordification.com/tech/tilt.htm
I will add that there are a few variations to the tilt wiring that you may run into, but nothing you can't get past. :wink:
bluef250
Post by bluef250 »
Check this out.
Are you installing a power steering box?
Corkwheats
My 71 truck does have power steering. I don't know whether this is a concern, or not. The tilt steering sounds nice. I may end up going that route. I'm just now starting to check around - an have limited cash right now. Thanks for the tips, guys!
Bob
Corkwheats
Well, finally got with my mechanic today - first words outta his mouth were, "If you're going to do this, you ought to get a 78/79 Ford Steering Column w/Tilt Steering". Thanks, guys. I'm definitely considering that option. I really appreciate the info.
Bob
Corkwheats
Does it matter whether the 78/79 Bronco Tilt Steering is from a 4WD or not?
Does it matter whether or not it had Power Steering or Manual Steering?
Mine is Automatic Transmission w/Power Steering & 2WD.
Thanks,
Bob
Diamond N
Post by Diamond N »
PM Sent...
68 F-250
79 F-150 4x4 (parting out)
79 Bronco (parting out)
