Wanted - 390 parts and 67 F100 parts needed
Re: Wanted - 390 parts and 67 F100 parts needed
What are the prices for the stuff in the pics.
- Ranchero50
The back $20, the front $30.
Come up, if they are worth more you can pay more, if less we'll work it out. Either way, once you have them I'll stop thinking about buying the weatherstrip and installing them.
What about the radiator?
- Ranchero50
$200 with the shroud. It's practically new.
Ok, ThanksRanchero50 wrote:$200 with the shroud. It's practically new.
- Ranchero50
Yes, no, maybe? Make offer?
I'd be interested in the front and rear window trim.
67 spare tire carrier with hardware
blue seatbeats
radiator support for 390
390 radiator for automatic
67 sun visors
390 flexplate - need 3
driveshaft for a auto c6 2wd w/8ft on a 1/2 ton
window weatherstripping
door weatherstripping
shift indicator window
390 engine motor mount hardware
390 dizzy hold down clamp
390 radiator fan shroud
67 headlight doors aluminum/chrome ones
heater control valve
horn relay
horn(s)
horn wiring harness
67 door jam (2)
67 wiring harness no cargo switch
brake warning light switch
cargo switch delete panel
door sills
67 headlight rings
67 washer pump
67 taillight harness for a 8ft bed
67 door jam brackets
passenger side inner fender
chrome stainless steel rear window molding/trim
chrome stainless steel windshield molding/trim
blue seatbeats
67 sun visors
horn relay
horn(s)
horn wiring harness
67 door jam (2)
door sills
67 headlight rings
67 washer pump
Still need parts
- 69SCJ
I have a flex plate, bolts, and reinforcement ring I just took off a 390 last weekend. $40 plus shipping?????
If interested, PM me an email addy that I can send pics to if you want.
Tyler
Tyler
68 f100, 390, 4x4, NP435, LWB, 33/12.5/15's, power steering.... work in progress!!!
- 69SCJ
I also have a dizzy hold down and a set of brand new door weatherstrips.
Sent you a PM.69SCJ wrote:I also have a dizzy hold down and a set of brand new door weatherstrips.
- 69SCJ
Got it. No problem on the delay.
I'll send you pics this weekend.
Tyler
Tyler
Still need parts
