I am looking for a rear drive line for a short wheelbase f100 4x4. Let me know what you got, mines starting to vibrate a little. I know I can get one made, just thought someone might have one they don't need.
Doug
4x4 rear driveline
4x4 rear driveline
1967 f100 4x4
1970 f250 4x4
1970 f250 4x4
- harrysnyder
Re: 4x4 rear driveline
Doug,
Check the slip joint in the shaft. Chock the rear wheels, and with the truck in neutral, look for clockwise/counter-clockwise play in the slip joint. Since you said that you just recently started getting a vibration, that leads me to believe its probably a wear item such as universal joints or the slip. I can repair your shaft with new stuff and save you the hassle of looking for one and potentially buying another one with alot of wear in it already. Feel free to call me at the shop, 864-597-1916
I build driveshafts.
www.carolinadriveline.com
71 F100, 302, C4, 8.8, crown vic swap
68 F250, 360, NP435, Dana 24, Dana 60's f&r
I made this drive line out of parts I had around. It has up and down and rotational wear at the slip yoke. And the u joints are shot. The tube and slip yoke are from different drive lines. I will try to call you monday. Thanks.
Doug
Doug
1967 f100 4x4
1970 f250 4x4
1970 f250 4x4
