1967 Brake pedal
Calvin Gunter
1967 Brake pedal
Post by Calvin Gunter »
I need the brake pedal for a 67 only with automatic transmission.
TIA,Calvin
1967 Ranger,Short bed,390,C-6,9 inch,4 BBL.,intake,cam,headers,3:55 Posi.,A/C,Power steering,Power Disc Brakes,Automatic trans.DJM dropped I-beams,flipped rear hangers,headlight harness upgrade.ExTang tonneau cover "Old Blue".
http://s508.photobucket.com/albums/s328/BigSxy96/
1967 Base model,352,2bbl.,3 on the tree,short bed,3:25 9 inch "Rusty".
1967 Mustang coupe-show car/garage queen.Small Block,alum. heads,Nitrous,4:11Locker,Areospace brakes "Mystang".
1996 F-250 Powerstroke-Big intake,exhaust,injectors.(Nice Smoke Show) "Big Sexy"
71PA_Highboy
Re: 1967 Brake pedal
Post by 71PA_Highboy »
I was under the impression that the 67 brake pedal was the same for manual or auto trans... it was the cross shaft that was welded to the clutch pedal for manual trans and just a shaft for autos... hence the same brake pedal.
I may be wrong...
http://www.fordification.com/tech/67-72ID_02.htm
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
67mann
Post by 67mann »
:hj: So the assembly worked for you :D is it installed :?
Calvin Gunter
No I haven't installed it yet.
I'm rebuilding and painting the bracket I got from you.
I'm still collecting parts to swap over to 429,C6,power steering.
I guess I can use the current brake pedal.
I was just going to have everything ready to install without having the truck down and imobile.
So if anyone has one let me know.
TIA,Calvin
kingcarz
Post by kingcarz »
I have a ford automatic brake pedal, it is the small one, pedal & arm, brake switch bracket. Came off a F-250 automatic, put into my 68' F-250 4x4, I used the same housing to put a long brake pedal pad on, I had to shave some of the collar to make this work though, but works great, so if you looking for the small brake pedal, I have one,
Calvin Gunter
Thanks for the replies guys.
I have a small Ford pedal that I got from 67mann but I'm looking for a 67 only if I can locate one.
TIA,Calvin
