my green 68
- tybob81
Re: my green 68
newly covered 95 f150 seat.
- tybob81
Re: my green 68
Dusty engine compartment. Doing some rerouting of the painless harness.
Re: my green 68
how did you do the wood in the bed?
- tybob81
Re: my green 68
I built new rear and center crossmembers and modified the front crossmember. Made a track on the sides for the wood to slide into also.
Re: my green 68
Wow, that has got to be one of my top 10 favorite bumps. Very, very nice.
1970 F250 Camper Special
"Its no coincidence that man's best friend can't talk."
Re: my green 68
BiggDogg wrote:Wow, that has got to be one of my top 10 favorite bumps. Very, very nice.
- undertakerman
Re: my green 68
I like your color. Green is one of my Favorites. I'm restoring a 68 Flareside 8' bed and I'm painting it Sassy Grass Green which is a 69-70 Mopar color. I use to have a 69 Roadrunner that was Sassy Grass Green with Black interior. This interior will be Black on Green. Good looking truck. You did a great job.
You know man can live alone, but he cannot live without Peanut Butter and Grape Jelly.
Re: my green 68
Great looking color. And awesome work on your truck. I only hope I can do that well on mine.
Re: my green 68
that is the coolest green i have ever seen.tybob81 wrote:[ Image ]
Re: my green 68
nice color and it looks that u have done a great bodiy work also!!!
- tybob81
Re: my green 68
Thank you.....I have a ton of hours blocking this truck till it was straight as an arrow.
Re: my green 68
Hey tybob81,
I see you have a tilt column in your beautiful truck, what brand and part number did you use?
Any problems with the install ?
TIA,Calvin
TIA,Calvin
1967 Ranger,Short bed,390,C-6,9 inch,4 BBL.,intake,cam,headers,3:55 Posi.,A/C,Power steering,Power Disc Brakes,Automatic trans.DJM dropped I-beams,flipped rear hangers,headlight harness upgrade.ExTang tonneau cover "Old Blue".
http://s508.photobucket.com/albums/s328/BigSxy96/
1967 Base model,352,2bbl.,3 on the tree,short bed,3:25 9 inch "Rusty".
1967 Mustang coupe-show car/garage queen.Small Block,alum. heads,Nitrous,4:11Locker,Areospace brakes "Mystang".
1996 F-250 Powerstroke-Big intake,exhaust,injectors.(Nice Smoke Show) "Big Sexy"
- tybob81
Re: my green 68
It is an early IDIDIT column for a 67-72 truck. It is the metal housing one. I think they have a ford plug now, nut this one had a gm plug and o made an adapter plug from an old column to plug a gm into a ford painless harness.
Re: my green 68
Thanks tybob81,
Do you remember the part number you used?
I see they have a retro fit for our trucks.
Was yours a direct bolt up or did you have to modify anything other than the wiring.
TIA,Calvin
TIA,Calvin
- tybob81
Re: my green 68
Bolted right up an as far a a part number I can look....been over 5the years since I bought it.
