Bleeding Front Hubs
qman
Bleeding Front Hubs
Post by qman »
What kind of wrench do you use to bleed the front hubs? A combo wrench goes onto the bleeder valves at an angle so the wrench is only half on the valve. I was able to get the driver's side valve loose but not the passenger's. Is there a better tool do do this with?
72 F100 2wd 360 C6 Custom w/factory PS.
hunter01762
re: Bleeding Front Hubs
Post by hunter01762 »
Try an offset wrench
Lord, give me the restraint not to cuss over busted knuckles.
qman
Post by qman »
I don't know what an offset wrench is. Is that what they're called in a parts store or Sears?
off set is not straight. it is bent just before the head of the wrench. giving an offset to the wrench.
spartman
Post by spartman »
Here is what they would look like:
http://www.kyototool.co.jp/english/nepros/wrench.htm
qman
Post by qman »
OK, now I know what you're talking about. I think I have one of those but not the right size. That's one type of wrench I don't have. Thanks guys. I didn't even think of that.
