The swap is on
- Joshpow
The swap is on
My disc brake swap should be on for in the morning. Hope all goes well. 1 helper not gonna get to help. just 2 of us. Maybe get it all swapped tomorrow. Gonna swap front axles etc lines and calipers. If enough time swap rear wheel cylinders and rear lines. Hope to get it all done cause powerstroke has bad radiator so need the ol bump!! Wish me luck.
Josh
72 F-100 Ranger XLT SWB
71 F-100 Custom SWB
67 F-350 Dually Dump
02 F-250 Stroke
71 F-100 Custom SWB
02 F-250 Stroke
- forrestbump
Re: The swap is on
Josh, if you're looking for a welcome, well OK...here goes! Welcome Josh from SoCal . Haven't you already been here for a little while though?
Well it's always great to give old and new members a WELCOME!!
...oh yeah...Good Luck!!!
Larry
Larry
- Joshpow
Re: The swap is on
no welcomee needed. just dropping note to people who talked to already. screwed up where i put it!! go figure! Meant for gen discussion!! What an idiot i am!!
Josh
71 F-100 Custom SWB
02 F-250 Stroke
71 F-100 Custom SWB
02 F-250 Stroke
- Ranchero50
Re: The swap is on
How did it work out? Last time it was just me, the jack and a ratchet strap. Git-Er-Done
Jamie
Jamie
- Joshpow
Re: The swap is on
It worked. Pain to get everything lined up. For some reason the ibeams didnt want to line up quite right. Had to do some jack work and clamping to get them to line up and then all went fairly well. Hardest part was getting pivots aligned and bolts in. Done and driving tough!
Josh
71 F-100 Custom SWB
02 F-250 Stroke
71 F-100 Custom SWB
02 F-250 Stroke
