Column/box replacement
Chromepro
Post by Chromepro »
I'm replacing the Bendix setup on my 68 Ranger 2x4 360, with a Saginaw box and 79 column. Any ideas on crossover years for pitman arm, engine-side firewall column bracket (for P/S), and engine perch/stand? I've found 73 parts on the net at a bone yard, but since I can't see them, wonder if they would work as 68-72 do?
72hiboy4x4
Post by 72hiboy4x4 »
First off, Welcome to the site! post up on the welcome mat and be officially welcomed!
second, read this for the answer to all your questions.
http://www.fordification.com/powersteering.htm
then whe you have more ??, the guys here will be able to help you out even more!
