Breaking them "side-ways" ;)
Quick question about my newly acquired F-250 390 AT
When the ground is wet, I have to apply the gas VERY slow and softly, otherwise my rear end breaks loose. Same thing happens on the freeway when I am at say 50 or so and step on it hard. Is this because I have NO weight in the back, or old OLD tires, or maybe something needs work in my rear suspension? Or just perhaps because it is a beast of an engine?
Re: Breaking them "side-ways" ;)
it could be all of the above. too much torque for the truck with no weight in the back of it. wet weather will do that to alot of vehicles though.it may be just too much engine though.
- BRUTUS_T_HOG
are the tires worn? i say all of the above
ASE Certified Technician
- BobbyFord
Mine does the same thingSweetblu wrote:Quick question about my newly acquired F-250 390 AT
- Mancar1
Is this a rhetorical question? Pavement wet, push down on pedal, tires spin. Hmmmmm, happens to me also.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
- evan_flatt69
I just call it fun
1969 F-100 Short Bed Custom Cab 390
1985 BMW 635CSi
1985 BMW 635CSi
I think sweetblu is just bragging
1967 f100 stepside 300ci I6
1969 f100/600 stepside retro truck -under construction-
1972 longbed trailer
- Florian
You have to go real gently in wet weather or the tires will spin, even with brand new tires I guess. Bad tires will make it worse of course.
1971 Ford F100, 302cui, 3 on the tree
- ford4x4fun
CNR Radio Instructor
US ARMY Retired
1971 Ford F100 4x4 (390)
2015 Ford F250 Crew Cab 6.7l
US ARMY Retired
STROKER69 wrote:I think sweetblu is just bragging
HAHAHAHA I wasn't bragging
- fbomb100
hell my will do it dry even with little gas as i turning all the time and when wet even more so ..and from a dead stop i smoke'em and it just stock just with gears
- ezernut9mm
x2. set the hook and reel them in.
