Power Steering Questions
Re: Power Steering Questions
after 79 the only thing you can use is the power steering pump the brackets and maybe the hoses. the column wont work or the power steering box.
whiteblur
Post by whiteblur »
if i get those parts off the truck what will i need to find then? What do you think a good price for those parts would be? Does it make a difference that my truck is a 3 on the tree? will i need to find a 3 speed steering column?
the bendix power steering is the easiest way to do a 3 speed column . since the 3 speed saginaw columns are a little more harder to find than the bendix boxes. a 3 speed saginaw column is going to be more expensive too.
forrestbump
Post by forrestbump »
http://www.fordification.com/tech/powersteering.htm Explains what all is involved with adding powers steering, including modifications necessary to your 3 on the tree steering column.
As Fordman said, the best power steering gear that will bolt up to your Bump properly is a 1968 through 1979 Ford / Saginaw steering gear box. 1980 and newer F series trucks are "Front" steer whereas ours are "Rear" steer.
You can use a Bendix power steering gear (if you can find one), and it will fit without modification to your steering column, but they are not as durable as the Ford / Saginaw steering gears. They can be found in 1965 through 1967 Ford trucks.
Larry
