Hey guys just wanted to run this idea by you and get your imput. I am currently not impressed with any new trucks mostly due to imissions and having to add urea in the new diesels. As a huge fan of diesel performance this is an issue . I am thinking for prolly less money than a new pickup I can build my dream truck. I want to put a 67-72 (any year I dont care) crew cab short bed body on a 99-04 super duty frame. For drivetrain I will go with a P pumped 24 valve 5.9 cummins-NV4500 combo and use the rest of the super duty drivetrain. I would love to hear all your imput about this project so I can get a better idea of what im up against.
Thank you
Josh A.
1970 F100 4x4, 360 FE, NP435, 9", factory 4.10, Homemade 4" lift, 35/12.5R15 MT Baja Claws- ultra budget 4x4 toy
2001 F250 4x4, Powerstroke diesel, auto, 140hp TS Performance chip, AFE cold air intake, hopefully adding soon- Jobe performance cold air intake, CFM+ intake manifold, 4" turbo back custom duals, stage 2 injectors- Daily Driver
Hot Rods have a Ford in front and a toolbox in the back, street rods have a chevy in front and a can of wax in the back- Mr. Offenhouser
07 Harley Davidson Nightster, 1200 with stage 1 programming, RSD intake, straight pipes, and Ape Hangers!
If your going to go with a cummins powerplant then it would be tons easier to use a newer dodge frame. That way your not trying to fit a different motor to a different frame and a different frame to a different body and a different body to a different motor. By going with three different sources to build the truck your asking for three times the misery in getting everthing to work. I also know that you can put a classic Ford truck body on a late model dodge because Trucks did it on TV not to long ago with a dent side. It's called Project Super Dually they started it back in 2009. Here's a link to one of the episodes they worked on the truck.
I think the cummins swap part will be fairly simple because you can order motor mounts, tranny adapters, complete wiring harnesses and all the other nececites from destroked.com. I am not a fan of dodge front ends so I would prefer to use the super duty, plus I want to keep is as much Ford as possiable.
