dodge dakota swap
dodge dakota swap
i have heard some about using the dodge dakota swaps for the slicks. i went over to the slick site and saw a little. but what i didnt see was what year dakota stuff to use and how the steering column was attached to the dakota steering box. and would i need to remove the crossmember from my frame and use the dakots crossmember. woudl there be any reason to do that? would it drag the ground?
yeager351
Re: dodge dakota swap
Post by yeager351 »
I remember this swap but it was years ago. It was a company in arizona that sold the kit. But the article i read was performed by a rod shop in Shreveport La. They also did a vent window delete on the truck. This was when i lived in south Ark and i always wanted to get this done. But of course I had no $$$. The article was done on a Bump. Thats the best i can do!?
do you know where i might be able to find the article? what magazine was it in or web site? i figured out the steering column. im unsure about the crossmember though.
survivorman
Post by survivorman »
Forgot one thing.
In my area a clip job runs about $600-800 for the work, and they don't always include motor mounts.
Sitzungstiefpunkt und fahrend langsam
i dont think the frames are the same width on the dakota i have and the 72 frame i have. i seen over on the slick site where they removed the straight axles and made a engine crossmember to mount the steering rack to and then welded the a arm mounts to the original frame.
survivorman
fordman wrote:i dont think the frames are the same width on the dakota i have and the 72 frame i have. i seen over on the slick site where they removed the straight axles and made a engine crossmember to mount the steering rack to and then welded the a arm mounts to the original frame.
There not, but he made it work.
The track widths are close enough, and I would cut off what I need. Then fab it to my trucks rails.
here is what i have to work with. i dont see why anyone would need a new crossember though. surely the A arms could be attached to the ford crossmember if it would clear the ground.
MadMaxetc
Post by MadMaxetc »
I think you will have a lot of Fab work to do if you try to keep the stock crossmember. I would try Splicing in part of the Dakota frame.
The Dakota frame slopes up a little as it goes forward to the bumper, but a bump frame in almost level.
Talk a look at my Install of the ICI crossmember in my early slick (63).
http://s63.photobucket.com/albums/h142/ ... ta%20Swap/
Can you post a picture of the frame look almost straight down? Also, how wide is the frame right above the steering rack vs your bump frame?
Dan
FORD Girl
Photobucket Pictures
the dakota frame is narrower. i measured it today. i will get some more pictures. i am not sure this is goignt o be something i am going to do because fo the narrowness of it.
ezernut9mm
Post by ezernut9mm »
i think it was el pollocko that did that.
industrial chassis was the company's name but it is on hold as far as i know.
http://www.youtube.com/watch?v=dd4BLVkQOhQ
that is a powerful truck to do that in such a short distance.
