I'm putting a 71 column into my 68 (floor shift 2 wheel drive). The wiring is different the 68 has two plugs, the 71 has one. Does anyone know, or can post a link that shows how the wires match up? I've spent the last 20 minutes searching, but haven't been able to turn it up.
Thanks,
Mike
wiring to convert a 71 column to a 68 column
Re: wiring to convert a 71 column to a 68 column
see if these help the first one is lmc wire conversion if you buy thier switch. the second are notes i took while pinning the plug in my 67. the third one i think either thunderfoot or mayeb kaptkaos had posted at one time and i copied it to help others on the forums.
Thanks Fordman. Finally had an opportunity to decipher all of this - looks like the LMC diagram was the most helpful.
