help with after market wheels!!!!!!!!!
fiyaweed06
Post by fiyaweed06 »
hello i have 1972 ford f-100, and i know a guy thats selling some aftermarket wheels that he has on his 1998 ford explorer. the wheels have two different bolt patterns will they fit on my ford f-100, i know the pattern that he is using on his explorer will not work but will the other set of holes work.
ezernut9mm
Re: help with after market wheels!!!!!!!!!
Post by ezernut9mm »
usually it is 4.5 and 4.75 on a wheel and 5.0 and 5.5 on a wheel. what does the exploder use?
fiyaweed06
they are 4.5 on the explorer
fiyaweed06
i know one set of holes on the wheels are 5 4.5" do anyone know what the sizes of the other holes are
forrestbump
Post by forrestbump »
Your F100 has a 5 on 5-1/2" bolt pattern on your front hubs and rear axles. Just measure, diogonally, from lug hole to lug hole to determine if these wheels will "bolt" up or not.
Larry
ezernut9mm
actually, on a 5 lug wheel you measure from the center of one lug hole to the end of the second hole over.
https://www.rsracing.com/tech-wheel.html
if i were a betting man, id say the explorer wheels will not fit. the large pattern is probably 5x4.75. you need 5x5.5 like forrestbump said.
fiyaweed06
thanks guys
70ford1
Post by 70ford1 »
Hello---I just became a user ofthis forum & was reading the replies to this post. If you haven't found your wheels try this site--
http://www.lmctruck.com part # 48-3563 16x8x5-w/5.5 bolt pattern. Not standard style steel but a nice wheel & the only place I've found 16" 5 hole wheels. Hope this helps.
