i know for certain that neither of the 69 f100's i've owned (including my ol' #1) nor the 68 merc m100 did ....
rivets in manual trans trucks? wow. glad i never attempted a windsor transplant into one of thosecdeal28078 wrote:Far as I know the bumps with the bolts on the transmission cross-member and the radius arms are the ones with an automatic transmission from the factory. You almost have to remove that cross=member to pull the automatic transmission.
Mine came with a 302 and manual tranny and had rivets. Had a 72 F250 with a 390/c6 and it had bolts. Worked on many with C-4's and or C6's and they all had bolts and tall tranny covers. Hope this helps
clint
i had to totally remove the radius arm crossmember in order to yank and replace the engines & trannys as a unit ,lemme tell ya its a bit of a fight to get that sucker back into place after everythings said and done...onetuford wrote:My truck was a t-85 swapped to auto. Due to the small hump I did have to unbolt the c member and push it forward to change trans.
