68 brake cable part #
Does anyone have the rear park brake cable #s for f-250 w/ aux. tank and dana 60. the parts houses books ommit them. are they the same as f-100[doubt it] are they the same as 67 or 70?. Ron
- 460 crew
re: 68 brake cable part #
What do you need a parking brake for? These trucks don't much roll even with a person pushing them. ![Razz :P](./images/smilies/icon_razz.gif)
- 4x4x4crewcab
I read the following:
67/69 F250 4X2 12.125 X 2 brake R.H. 75 19/64 long C7TZ.2A635.K
L.H. 75 39/64 long C7TZ.2A635.L
67/69 F250 4X2 12 X 2 1/2 brake R.H. 72 21/32 long C7TZ.2A635.C
bx brake &camper before ser#d96,001 L.H. 73 21/32 long C7TZ.2A635.D
67/ up F250 4x4 R.H. 73 21/32 long C7TZ.2A635.F
L.H. 73 21/32 long C7TZ2A635.E
F100 is all different. Also 69 F250 4X2 is different and 70 f250 4x2 also different. Hope this helps
Mark
1969 Volkswagen Karmann Ghia
1999 Ford Windstar
1983 Chevrolet Silverado p/u
1990 Lincoln Town Car
1998 Lincoln Town Car
1999 Ford Windstar
Mark; Can't thank you enough!!!!!!!!!!!!!!!!!!!!!!!!!! Where in the heck did you find this info? Ron
- 4x4x4crewcab
Master parts catalog. Glad to help its kinda what I've done for the past 20 years. ![Very Happy :D](./images/smilies/icon_biggrin.gif)
Mark
1999 Ford Windstar
1999 Ford Windstar
- turbocharged400sbc
i had the same problem with finding the passenger rear cable for my 68 F250 2wd Dana60....i could not find anyone who had it (found two of em for the drivers side though...damnit)
so i went to a Plow/truck equipment place that had the correct ends and they made me a new one with all the good stuff (teflon liner double sheath with a nylon outter cover and with stailess end clips)...they made it to match my busted one...cost me 130 out the door...and he said ~70 over the phone...but it was because i had rare ends (lol) that cost more...
works great and i went and used silicone oil to lube all the other original cables...should last ferever now....
at one point i was gonna swap 79 D60 brakes/backing plates on it so i could use those more common cables...
Then i drove the truck from SoCal all the way to here in IL....and only had to replace driveshaft ujoints in Oaklahoma...and the radiator when i was 5 hours from home in IL....
I dont think i will ever drive it in this damn roadsalt....
Regards, James
Regards, James
1994 Olds 442 (425 cid-4 wheel drive-2 V6's) http://www.cardomain.com/id/94twinengine442 13.81 @ 98.2 MPH 1.9s 60's
68 F250 Camper Special 390FE/NP435/3.73D60
soon: 79 F350 disk brakes w/ 3.55 D60, pneumatic, 1750w AC inverter, Vector 1600w lightbar, 200A 3g alt, all a mobile gearhead needs
James : Hey there. I'd be almost happy at 130. just to get it done. i'll reseach it here locally. thanks. Ron Hey Mark: I,m in the service end for 20 now. current day stuff. If you need any tech info. Let me know. Ron
If it helps any it was in an industrial/comercial area near Point Loma (found them outta the ElCajon Phonebook) and they made their own cables for big truck plows they even had PTO stuff etc...
If my F250 wasnt in storage i could grab the reciept from the glovebox...and give you a name and # but i cant...
youll find a place somewhere...
good luck....
good luck....
- 4x4x4crewcab
Ron
Which numbers from the list are correct for your truck?
I have found the following places that show some of these:
KAMA OBSOLETE FORD PARTS
E BETHEL, MN 763-434-0123
C7TZ2A635L 2
C7TZ2A635D 1
BOWMAN SALES & SERVICE
BOWMAN, ND 701-523-3257
800-472-2218
C7TZ2A635L 1
PARTS INTERNATIONAL
FARMERS BRANCH, TX 972-241-8730
888-727-0418
C7TZ2A635L 1
GREEN SALES
CINCINNATI, OH 513-731-3304
800-543-4959
C7TZ2A635L 9
C7TZ2A635C 6
C7TZ2A635D 4
WESLEY OBSOLETE PARTS
LIBERTY, KY 606-787-5293
C7TZ2A635K 2
C7TZ2A635L 1
C7TZ2A635C 1
DALE KING OBSOLETE PARTS
LIBERTY, KY 606-787-5031
877-246-1111 C7TZ2A635K 3
C7TZ2A635L 1
DENNIS CARPENTER FORD REPRODUC
CHARLOTTE, NC 704-786-8139
800-476-9653 C7TZ2A635K 1
C7TZ2A635L 3
DEALER AUTO PARTS
APACHE JUNCTION, AZ 480-288-9878
800-640-3321 C7TZ2A635K *
C7TZ2A635L 1
ED BENNETT FORD PARTS
LEBANON, PA 717-272-8762
C7TZ2A635K ST
C7TZ2A635L ST
NOS ONLY
SAN JOSE, CA 408-227-2353
C7TZ2A635K ST
C7TZ2A635L ST
C7TZ2A635L 2
C7TZ2A635D 1
800-472-2218
C7TZ2A635L 1
PARTS INTERNATIONAL
888-727-0418
C7TZ2A635L 1
GREEN SALES
800-543-4959
C7TZ2A635L 9
C7TZ2A635C 6
C7TZ2A635D 4
C7TZ2A635K 2
C7TZ2A635L 1
C7TZ2A635C 1
C7TZ2A635L 1
C7TZ2A635L 3
DEALER AUTO PARTS
C7TZ2A635L 1
C7TZ2A635K ST
C7TZ2A635L ST
NOS ONLY
C7TZ2A635K ST
C7TZ2A635L ST
Mark
1999 Ford Windstar
1999 Ford Windstar
Mark: thanks yet again! c7tz-c and d are my application. i'll start with green sales. I owe you. Ron
Mark: I found both rear cables at Green sales. 60. per side for re-productions. Very resonable. Ron :
- 4x4x4crewcab
Glad it worked out for you. Your welcome,anytime
Mark
1999 Ford Windstar
1999 Ford Windstar
