Stock Steelies?
Ks Highboy
Stock Steelies?
Post by Ks Highboy »
Found these stock steel wheels and they have some differences. The black one has gaps where the inner wheel attaches to the rim and the white one is solid. The black ones came off a 67 F250 and I don't know what the white ones came off of. I have two more like the black ones but the offset is different, the rim looks shallower by an inch. Can't decide if I want to run two different styles but keep the same offset or run all four that look like the black one. I never new there were so many variables in these wheels until I started digging.ImageImage]
Ks Highboy
Re: Stock Steelies?
Heres the white one.Image
Ks Highboy
Re: Stock Steelies?
heres the shallower wheel that is like theImage black one.
71highboy
Re: Stock Steelies?
Post by 71highboy »
i dont know about the wheels but put some pics of that truck that in the background.it looks sharp.
Ks Highboy
Re: Stock Steelies?
Its For Sale!
Re: Stock Steelies?
Ks Highboy wrote:heres the shallower wheel that is like the[ Image ] black one.
this one looks like it uses a innie fitting hubcap.
as far as the others. all three big automakers used mostly the same lug paaterned wheel. because of the dana lug spacing. some chevy wheels can have a smaller center for the hub to fit on. but all 8 lug ford and i think all dodge wheels will bolt right on with no problems.
finding a complete matching set is part of the fun of redoing these trucks the way you want them.
Ks Highboy
Re: Stock Steelies?
Well, I know they will fit a ford axle since the guy that had the white ones had them on a pickup bed trailer. And yes they are for the innie hub cap which is fine. I think they look pretty cool. Just not sure if I'll notice the offset difference once they are on the truck. They are all 16.5x9.75 but the two black ones are a 6" backspacing and the two white ones that look identical are a 5" backspacing. The other two white ones are 6" backspacing but they are the solid wheel all the way around rim.
Hawkrod
Re: Stock Steelies?
Post by Hawkrod »
The white wheels are actually pretty hard to come by. They were used for rears on trucks carrying heavy loads like campers. The 4X4 guys are begging for them if you have 4 (and yes, I do have a pair myself). The later outie ones are also tough to come by but easier than the early innie style. There are a lot of people who want them and I would have mine sold (well I did he has been waiting a long time) if I could just find the time to get the tires dismounted! I run them on many of my F250's. Hawkrod
Bigs and littles on my Crew:
Bigs on all 4 corners of my 4X4:
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
(3)68 Cougar XR7-G's
69 Cougar 428CJ 4 speed
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
Ks Highboy
Re: Stock Steelies?
Thanks Hawkrod. I love the looks of that dent! That is the look I am going for. If that guy doesn't buy em let me know.
SoCalExile
Re: Stock Steelies?
Post by SoCalExile »
Did they make those in 5 lug?
Hawkrod
Re: Stock Steelies?
Post by Hawkrod »
There were not stock ones in 5 lug but they did make them as they were very popular with the Jeep crowd. I have had both 15 X 8 and 16.5 X 9.75 in 5 lug and I also know there were other sizes. You have to remember that there were about a half dozen companies that made rims for Ford but they also made them for the other manufacturers and for the aftermarket and so you will find a lot of the components were used to make combinations that Ford did not offer. This is good because the Ford caps will fit many of the other rims. Hawkrod
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
