1971 f250 DESERT truck- 10/24 race prep
Re: 1971 f250 DESERT truck- 1/6 suspension
Cool in True Blue Trucks this month there was a big write up about PMC Racing.......it was a good read oh ya and I saw this in there
60 Mercury Comet
65 Ford Econoline
77 Ford F250 "lowboy" 4x4
09 Harley Xl1200c
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
- 1971ford
Menace,Menace Kustoms wrote:Man, why can't I find deals like that? All I need is bent beams and coils so I can clear 33s. Dang. Well, you will be driving right by me on your way,.
I'm thinking I'm going to get rid of the coils, 1 ton bent beams and radius arms all in one bundle that i just took off the race truck.
Come get them.
Yep my dad bought that issue and got me a subscription to the article, perfect combination of off-road racing and old ford stuff all in that one magazine, it was cool!FordTruck wrote:Cool in True Blue Trucks this month there was a big write up about PMC Racing.......it was a good read oh ya and I saw this in there
New vs. old
THe solo swing set we are borrowing to look at the geometry but my swing set is going to be totally different. It will be pivoting from the inside of the frame most likely.
Finding out exactly where the mounts need to be will be fun..
Problem #1 is that on the passenger side the j-beam can't bump out 1/2" below the frame rail like how i was planning on bumping it. I am probably just going to trim those plates down on the i-beam pivots and plate the gap closed to give it strength, so i can still bump the truck to just about hitting frame.
Problem #2 is that I had to pop the misalignment spacers out because they were way too wide. I'll have to get new spacers that arn't as thick. But even then the uni-ball cup is way too wide for the beam pivots. The j-beams can't fully droop before the uniball cup binds with the pivot walls. I'm thinking i will just cut the sides of the cup down a little, but haven't looked at it yet.
Not exactly where the shocks will be but close. just seeing where everything is going to fit
Pulled the lights and skid plate, because the bumper is next to meet the sawzall
All the skid plate tubes are going byebye because the truck will need a new skid for swinger steering.
While i'm at it i might as well make a new bumper
-Ryan
- 67mann
Re: 1971 f250 DESERT truck-1/17 j-beams
Very
that your truck made it into a Mag.
And get some more Fire Extinguishers in that Garage,before ya burn your parents house down
- Menace Kustoms
Man, you had to drive by my house to grab those J-beams, you shoulda dropped them off! PM me though if you're serious, maybe we can work something out.1971ford wrote:Menace,Menace Kustoms wrote:Man, why can't I find deals like that? All I need is bent beams and coils so I can clear 33s. Dang. Well, you will be driving right by me on your way,.
Come get them.![]()
Josh
1970 Ford F250 LWB
390 c.i./C6 Automatic
1970 Ford F250 LWB
- 1971ford
67mann wrote:Verythat your truck made it into a Mag.
And get some more Fire Extinguishers in that Garage,before ya burn your parents house down![]()
I thought about that, But I wanted to make sure nothing went horribly wrong with the j-beams in which case I would be making the J-beams out of the old beams.Menace Kustoms wrote:Man, you had to drive by my house to grab those J-beams, you shoulda dropped them off! PM me though if you're serious, maybe we can work something out.1971ford wrote:Menace,Menace Kustoms wrote:Man, why can't I find deals like that? All I need is bent beams and coils so I can clear 33s. Dang. Well, you will be driving right by me on your way,.
Come get them.![]()
There is the leduc swap meet in so-cal on feb 28th that were going to...
-Ryan
- Menace Kustoms
I'm down, PM me fo sho.
Josh
1970 Ford F250 LWB
1970 Ford F250 LWB
- 1971ford
I had a ratchet strap holding the j-beam up at ride height. Tried to slowly lower it and it released all the weight of the j-beam, allowing it to freely pivot down to the ground 2 feet below. Onto my toe. It is now a bloody colorful mess of pain.
working on the truck sucks while you're in pain but the desire to hit the dirt again over powers it.
Worked all day to get just the radius arm mounts positioned and started. At least that is out of the way. It takes so long, having to get the pivot in just the right spot.
First i established ride height which is 5 degrees on the kingpin but the knuckle takes awawy 5 degrees so I have 0 deg. camber at ride height.
Caster is set at 10deg. ride height.
Bump travel at ride height is 7 1/8" from frame to beam so i'm guessing 10" at the wheel of bump travel. leaving probably 9 or 10" of down travel.
plate is 3/16 and holes are punched for 3/4 grade 8 bolt
Bump. Justtt enough radius arm to frame clearance. Less shaft will show when the shock is mounted in tabs.
Drooop
The j-beams bind up, but an inch after full droop. It's the uniball cup on the beam that is binding. I'll grind an 1/8 out of where it is hitting on the cup and it will have more room
Ride height
Drooop
Ride height
-Ryan
- Menace Kustoms
Re: 1971 f250 DESERT truck-1/18 j-beams
19" of travel is very respectable. As long as it's not dirty hooker travel.
Josh
1970 Ford F250 LWB
1970 Ford F250 LWB
- 1971ford
Of course it's going to be dirty-hooker travel, it's i-beams!
-Ryan
- 1971ford
Today I didn't want to get dirty, just not in the mood with my foot. So I took a break from front suspension and mocked up the whole front clip and I am now working on mounting that.
Hood will have hinges that have pins in the pivot so the hood can be pulled off quickly or hinged up if i am by myself and autofab hood pins on the front.
Fenders use the stock 2 cab bolts and grill bolts. Fenders can still be removed in less than 5 minutes for testing or whatever. Grill will be hung off a 1" tube with tabs and a few bolts.
I love all the space in there to work on stuff, and you can see how much lighter the front end is now without the inner fenders, core support and second hood layer. although the engine cage tubing added some weight back.
-Ryan
- 1971ford
Re: 1971 f250 DESERT truck-1/18 front clip
Fab'd the upper/lower coilover mounts on each side and dad slapped the spindles/discs on for now.
20.5" wheel travel at KING PIN. 10.25 up and 10.25 down. Just happened to split exactly in the middle. So the numbers will be even bigger at the hub.
I'm satisfied!
Then set it down on its new front end for the first time. Had to go to work 10 minutes after putting the wheels on so only had time to droop it out for fun. I'll set ride height and bump it tomorrow.
Now i can roll the dang thing out and clean the garage.
I'm satisfied!
-Ryan
- BobbyFord
Re: 1971 f250 DESERT truck- 1/31 It rolls!
That looks awesome Ryan!
Nice work!
Nice work!
- fomocoguy
Wow that's a lot of travel! Now if you get in a police chase you can jump a loading ramp or car hauler just like in the movies!
All kidding aside very nice work.
Joe
1971 F100 flareside 8ft
2006 Dodge Ram 2500 cummins
2005 Ford Ranger
2005 Ford Ranger
Great looking truck, I am gonna be doing something similar to mine. (probly not that extreme though) Great build!
- Ranchero50
So with the front end so articulating do you need to do something in the rear as well? 4 links or?
Jamie
Jamie
