Hello All. I guess I have the Bumpside Bug again
- Randle
After putting my trucks on the back burner for the last several years, I guess I have got the bug again. And now that I have retired, I have more time to spend on a hobby. I am in the process of checking out the trucks to see what kind of shape their in after setting for the last 4 or 5 years. I joined this forum severial years ago and never did get on and talk alot compaired to some, but enjoyed reading and getting ideas from all the good members.
I have 2 of these old trucks a 71 that I had started doing some body work on that has a stock (for now) running gear with a 390 and C6. The other is a 70 SB that is basically a truck body on a Mercury Marquis frame and drive train.
So I will get out of here for now and I will catch you a little later.
- basketcase0302
Re: Hello All. I guess I have the Bumpside Bug again
Randale,
from Choo-Choo town.
This will be right around the corner, you're maybe close enough to make it?
http://www.fordification.com/forum/view ... 10&t=56474
- forrestbump
back... sort of?! Once bitten by the Bump Bug, you'll never recover so y'all might as well accept it.
Larry
Larry
good to see you are getting back into working on your projects
- fireguywtc
back
Bill
- Mancar1
Hello from Northern Ca. I know what you mean about having more time when retired, I am semi-retired.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
- 1970FordTK
Welcome from North Carolina.
- hdpusher
Welcome from central Pa.
67 Chevy II 302 sbc
67 Ford F350 Motor home
68 Ford F100 long bed (Sold )
78 CJ5
03 Dodge Cummins
78 CJ5
03 Dodge Cummins
- Randle
Thanks for all the welcomes everone. Mancar1 it maybe good I do have a little more time now, because after thinking where I want to go with one of the trucks It just might turn into a full time job, but at least I want have to worry about all the old tales about idle minds.
- TheEskimo
Welcome back Randle
-Jason
1973 F100 Custom 390ci
1985 Thinderbird 302ci (DD)
- Randle
I just ran across some old pictures of the old trucks, the 70 in the gray primer is the one I will probably start on.
- guerra
1967 f-100 lwb 360/c6
1969 f-100 swb 351/c6 (project)
Welcome back! I like that 70. Thats gonna be a sharp little ride
- ta TACO
I definatly like the front end. Where did you come across that front bumper?
68 F-250 CS, 360 or 390?, still haven't measured the stroke, AUTO running on propane!
