So i really need your help! I need an alignment but cant until I replace my way bent pitman arm.
the P.O. took a grinder to it and notched it and its bent bad
the number on the pitman arm is C7TA-3590-AA. in the tech section the closest one is c7tz-3590. Also cant replaced the pitman arm until i know what year my PS gear is
the # on it is c5-ar-3580-a. Are the steering gear shafts the same on all 67-79 ps.gears? And last but not least.. what the heck draglink and tie rod setup is my truck from. maybe its stock but i cant find a single one that matches it. close but not the same. my tie rod end is on the p-side and the draglink attaches to the pitman arm from the top, not the bottom like most.
sorry for the long explanation but i have no idea what the PO has changed. I know you guys can help so thanks in advance.
