Well, cab is back sitting on the chasis.
A little pause as I ponder how to insure it is sitting correctly aligned prior to drilling the holes in the DC mounts.
Started bolting back up the brakes and found some more questions there. I did take a lot of reference pictures, I thought but if you are reading this and are not a Ford (insert your truck year and model) expert or thinking of a restoration like mine, reference pictures are very helpful.
Take a ton!!! every little bit and angle....and before you start taking things apart check how much it costs to replace. Since you might be suprised just how much it costs but since you had to use BFH or something that damaged it upon removal, you are now stuck to pay.
For example the inside of the cab firewall cover!
Anyway, pretty excited about this stage as it really is obvious that I am making the turn towards full reassembly. Not a show truck but nicely cleaned up and critical systems rebuilt or replaced.
Goal is to have it back on the road (without bed) by first weekend in April!!!
