MLJJONES67 PROJECT CUMMINS put away for winter
Re: MLJJONES67 PROJECT CUMMINS 3 updates 4/20/10
Thanks Tim. It is slowly getting there.
I feel like such a slacker!! I have not done a thing on my truck.
Re: MLJJONES67 PROJECT CUMMINS update 9/7/10
Spent some time today working on the frame. I was able to only get about three quarters of the silver bullet on. It looks pretty good. I need to order some more and some black top coat for the axles and springs.
looking clean. i can't wait till i can redo my frame. To me it's one thing that improves the looks 10 times.
1967 f100 stepside 300ci I6
1969 f100/600 stepside retro truck -under construction-
1972 longbed trailer
- 69rangerf100
so any progress on the build
David
- HRDROKN
Mike... you're doing a great job!!!
'69 Ford Cummins Crew Cab... Built 6BT main & head studs, ported & oringed head, springs, Ti retainers, marine cam, tweaked P7100, 4K gov kit, NV4500 w/1.375" input, Southbend 3600# DD clutch, NP271 w/SYE, D60 HP front, high steer, 16" coilovers & 4-link, D80 w/disc rear, 4.10's & LSD, spinning 38" x 14.fiddy's on classic slots..... more coming!
http://www.fordification.com/forum/view ... hp?t=23267
Thanks guys. Its all wrapped up and stored for winter so no work done on it. The wife wanted the garage for winter for some reason. Hopefully the rust wont be to bad once i un wrap it..
- 69rangerf100
Re: MLJJONES67 PROJECT CUMMINS put away for winter
i hate to here that. i to had to move my frame outside. but that was my own doing so i could do the body work on the cab
David
Well my build is still on, it will be put on hold until I can get back on my feet. I have started the auto detailing business and will have an income here pretty soon. I have changed directions a little bit because I sold some parts to get by. I sold the bed, 6Bt, and the diesel ZF5. I am still going Cummins but it will be with a 4bt instead.. In the end it will cost me a little more because I found the cummins and ZF5 for such good deals. And I will probably go back to a flat bed dump. Luckily nobody wanted to buy all the other parts so I will just hold onto them till I can get back on top of things. So for the next 5 months to a year the project is on hold..
- Manny
mljjones67 wrote:Well my build is still on, it will be put on hold until I can get back on my feet. I have started the auto detailing business and will have an income here pretty soon. I have changed directions a little bit because I sold some parts to get by. I sold the bed, 6Bt, and the diesel ZF5. I am still going Cummins but it will be with a 4bt instead.. In the end it will cost me a little more because I found the cummins and ZF5 for such good deals. And I will probably go back to a flat bed dump. Luckily nobody wanted to buy all the other parts so I will just hold onto them till I can get back on top of things. So for the next 5 months to a year the project is on hold..
Hope the new business works out good for ya Mike. Did you use the soda water blast stuff on your frame.
The Junk that hangs around
1974 Bronco 302 3 speed
1984 bronco 302 c6 35's
1994 F350 7.3 5spd dually.
- austin
bump love the truck should be sweet when you are done do you need any parts i know where a few are there all 70-72 trucks though
i dont know if you got my pm's back to you
