67 doors
67 doors
I learn something new every day. Today, knowing that the 67 doors have parts that only fit that one year and not wanting to limit myself to that I decided to cut the inner door panels from some scrap 69 doors and put into my 67 doors. Doing this so I can use the squeeze type inside handle and the longer arm rests. I did my passenger door first and after removing the door lock rod on the 69 latches everything worked very well. Then I decided to do the drivers door the same way and all went well until I tried to install the 69 door latch ( that's a no no). The screw hole pattern is the exact opposite of the latch (2 holes at the top and 1 at the bottom) on that door. Then I had to cut out the latch plate from the 69 and install it on the drivers door. I guess after Ford's workers ate lunch the first day of the 67 production year they came back and decided to do the drivers door different than the passengers door. Oh well, my preacher says if you ain't making mistakes, you probably ain't doing nothing. Go ahead and laugh, I deserve it. It is kinda funny.
Rick Allen
re: 67 doors
Yeah, that came up a while back here on the forums in this thread. By simply mounting the latch upside down on the opposite side they were able to use the same latch for both sides.
re: 67 doors
Hmmmm.....yep, you're absolutely correct! I engaged the mouth before the brain this time. (Oh well...it's not like it's the first time! )
