Lowering coil springs
texrodder
Post by texrodder »
Has anyone tried these 2" lowering springs from Blue Oval truck parts, if so are they worth the price?
http://www.blueovaltruckparts.com/i-398 ... -F150.aspx
Re: Lowering coil springs
i think i would cut my original springs first before paying that much for new springs. because new springs are going to be stiffer and 2 inches lower than original stock. the used orignal springs on your truck will already be worn and less stiff. so you will get 2 inches lower than yo uare now. and the new sprign will actually probably lift yo uup some even with the 2 inch drop they advertize.
texrodder
Post by texrodder »
Probably will cut mine, just wanting to see if having variable rate springs were worth the cost, had some on one of my lowered broncos a few years back and they performed way better than stock single rate springs, but these are over twice as much as later model F-series lowering springs.
BobbyFord
Post by BobbyFord »
As you probably already know, lowering by cutting the springs will result in negative camber and premature tire wear.
I have Moog variable rate springs in my truck and I like them (about $90).
texrodder
Post by texrodder »
BobbyFord wrote:As you probably already know, lowering by cutting the springs will result in negative camber and premature tire wear.
Yep I know, been around building trucks since the early 80's thats why I was asking if anyone had used these variable rate lowering springs, seems they are impossible to find now for our trucks, what is part # on yours and were they stock height?
BobbyFord
Post by BobbyFord »
Yes Sir, they are stock height. The top is the most wide spaced part of the spring and the area to cut them. It doesn't take much of a cut to get the desired results. Draw a line and measure the outside edge of the spring to make sure both are cut the same.
Summit part #MOG-CC808, $87.90 delivered to my door.
texrodder
Post by texrodder »
Thanks Bobby, thats alot better than $200 plus, thanks again.
