A couple suspension questions (pictures attached)
dcbullet
Post by dcbullet »
My 1968 F-100 currently has a 3/4 Ton rear end (Dana 60). I'll be switching that out for a 1972 1/2 Ton rear end (Ford 9 Inch). I have a couple miscellaneous questions that have come up.
1. The parts catalogs list shocks as being from 65-69 and 70-72. Anybody know the difference? Since I have a 68 truck and will be installing a 72 rear end, I'm trying to figure out which ones to order.
2. I've attached pictures of the rear springs. I was trying to figure out if I have the 3/4 ton springs or if I've got the 1/2 ton springs with some "helper" springs added on. Can any body tell offhand?
Thanks in advance if anyone can help.
heep70
Post by heep70 »
You have the flexomatic springs. http://www.fordification.com/forum/sear ... de=results
As far as shocks. It is probably the mounting location that are different. This will also lead to travel differences. Look and see if the mounting location is different between the two axle housings.
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
68F250
re: A couple suspension questions (pictures attached)
Post by 68F250 »
On the shocks, it's the top mounts that are different. Get the shocks for your year truck.
Barry
dcbullet
Re: re: A couple suspension questions (pictures attached)
Post by dcbullet »
68F250 wrote:On the shocks, it's the top mounts that are different. Get the shocks for your year truck.
:thup: Thanks.
My second question is mainly out of curiousity. I plan on leaving them as is, but I wondered what had been changed out by the prior owner.
He put the 3/4 rear end on because he had a camper shell.
Thanks again.
it looks like to me all the po changed was the axle and the spring. i haven't looked under my truck for quite some time but i think its the same frame mounts and stops as my 68 ranger
