Replacing factory Steering Wheel 69 F100
Macdaddy
Post by Macdaddy »
Thinking about replacing factory steering wheel with aftermarket wheel (Grant probably) anybody had any luck with a direct bolt on and still use factory turnsignal set-up? I just purchased a used 15" 3 spoke F series wheel off of ebay, it fits but will not work with current factory turn signal set-up...
69 F100
302/3 Spd.
Concord NC
Re: Replacing factory Steering Wheel 69 F100
why wont it work with your turn signal setup? it should unless the cancel cam nub has been removed from your steering wheel.
Macdaddy
Post by Macdaddy »
not sure what year the wheel came off of, but the entire hub is about an inch in diameter bigger then factory 69 f100, also the nub for the cancel cam is not there and i dont see a hole where it would have been..
69 F100
302/3 Spd.
Concord NC
Macdaddy
Post by Macdaddy »
just found out it came off 79 f100....
69 F100
302/3 Spd.
Concord NC
whoever told you a 3 spoke came off a 79 F100 is wrong. unless that is a typo. and you meant 1970 F100
by the sounds of it being too large around. it probably came off of a larger truck. the 3 spoke wheels werent used in F100-F250 trucks past 1970. i am unsure about F350. but i think the same 1970 cut off is the same. however the 78/79 steering wheels are larger around at the base.
one way to tell what size of truck it came off of is the deepness of the dish of the spokes of the wheel. the larger the truck the less of a dish the steering wheel will have.
michael69
Post by michael69 »
As far as putting an after market wheel on like a Grant steering wheel, as long as you buy the correct adaptor for your steering column and steering wheel your turn signals will work. That is if they were working before.
Michael69
1985 CJ 7 jeep w/35s
1967 SS Chevelle 502 4 speed
Macdaddy
Post by Macdaddy »
turn signals work fine...the ebay seller says the wheel came off a 1979 F100 Official Pace Truck, what ever that is...you never know with ebay! its 15" diameter, black leather factory wrap and 3 black rally spokes with Ford center horn cap...
69 F100
302/3 Spd.
Concord NC
oh its a sport steering wheel. no wonder it is a 3 spoke then. and is too large for your column.
trukcrazy
Post by trukcrazy »
Here is my Grant in my 67 and everything works. Just get the correct adapter from Grant.
John, #424
1967 F250 crewcab x 2.
2008 Challenger SRT8
Macdaddy
Post by Macdaddy »
Fordman, I believe your right about the sport model steering wheel, Im going to relist it on ebay....Trukcrazy, that wheel looks great, did you get a lower dish then factory too? Im hoping to get the wheel closer to the dash by at least an inch...does the horn work with all original factory guts and the adapter kit?
69 F100
302/3 Spd.
Concord NC
cep62
Post by cep62 »
Macdaddy , how much did you pay for the sport wheel if you don't mind saying ?
I've seen them go over $100. and I got $85 at a swapmeet once.
Macdaddy
Post by Macdaddy »
I paid 30 bucks and that included shipping, going to list it on Craigs List, see if I get any bites...
69 F100
302/3 Spd.
Concord NC
kilog55
Post by kilog55 »
if its a real ford truck sports wheel and in good shape you stole it lol they go for 250 all the time on the bay
1968 F250 Ranger 2wd 472ci TH400 Caddy powered.
1979 F250 Ranger 4X4 400ci T18
anyone need a 60x24x24 flatbed semi toolbox?
my gallery - http://www.fordification.com/galleries/ ... ?cat=10437
trukcrazy
Post by trukcrazy »
Macdaddy wrote:Fordman, I believe your right about the sport model steering wheel, Im going to relist it on ebay....Trukcrazy, that wheel looks great, did you get a lower dish then factory too? Im hoping to get the wheel closer to the dash by at least an inch...does the horn work with all original factory guts and the adapter kit?
It is shallower and smaller diameter than the factory wheel. I think it works great. The buckets in my truck sit a little high, but in my other 67 with the bench, it was really nice. Between the hardware that comes with the wheel and the mounting kit you buy for your application, everything works. The wood wheel stays cool in the summer and warm in the winter as well. My wife bought me that wheel in 2000 and I have put it in 3 different 67s. :thup:
John, #424
Hawkrod
Post by Hawkrod »
The price on that sport wheel is only good if it is a correct one, there are two different kinds. It is easy to tell the difference because the wrong one does not have any horn contacts on the back side. Those are the two round rings that the horn brushes run against. These wheels originally came out on Pinto's and Mustang II's (that is why they are so small!) and then were used later on several Ford cars and finally when the truck steering column changed in 78 they became an option on the truck as well. The early ones came in a few versions, they can be chrome or blcak and they can be padded or leather wrapped. The chrome leather combo is by far the most valuable. Starting in 79 Ford also used this design steering wheel on the Fox design Mustangs but the Fox chassis cars used a horn button that was part of the turn signal switch so they eliminated the horn contacts on the steering wheel and the backside of those wheels is smooth except for the wheel lock hub. The Mustang crowd does not seem to care much for these and I think it is because Ford realized that the turn signal mounted horn just sucked and changed it so many Mustang guys just change their turn signal switches to the later one and use a steering wheel mounted horn (I know I did!). The earlier version of the wheel with the horn contacts can be worth quite a bit of money as are the horn buttons themselves which break easily and are very hard to get. Hawkrod
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
(3)68 Cougar XR7-G's
69 Cougar 428CJ 4 speed
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
