Hello everyone,
First post in a LONG TIME.
Question: On my 1971 Ford F250 should the power steering feel...well like power steering? Sometimes the steering feels AWESOME, almost too good - then others it feels like things aren't meshing correctly. (Tough)
Any advice? Fluids are topped off. Could it possibly just be the PS pump?
Thanks in advance,
-Josh
Power Steering Issues
1971 Ford 360 C6
- one_am
Re: Power Steering Issues
Anything is possible. Could be the pump. how frequently does it act up and is it repeatable, i.e. Turning left/right first thing in the morning ect.
also check http://www.fordification.com/tech/PDF/F ... gnosis.pdf
69 F100 custom cab swb 460 c6 9 code rear axle (project).
bjde0b wrote:I jacked a sway bar off...
If it feels like it is grinding your cab mounts might be dropping putting a bind on the steering shaft. Bearings inside the column might be dry or bad. Rag joint might be bad. Do you have much free play?
clint
clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
1986 Bronco 5.0 AOD
If you don't have a P/S cooler on it, it could be heating up and overheating. Need to pin down when/why/how it doesn't "feel right".
Patrick
Patrick
Chevrolet
1969 F100 4X4 Highboy 390 3sp
1969 F100 SWB 2wd Auto 351w
1972 F100 Ranger XLT 302 Auto
http://mrsnicks.blogspot.com
