What 6sp auto? That would be sweet! I wonder if there is and Allison that would work....fbomb100 wrote:still thinking in putting a stroked fe in it and 6sp auto,, my budget is.nt the greatest either, so I'm wheeling and dealing some car parts to help out my budgetdad23boys wrote:Looks like you got a good find. You will be very pleased on how well your truck drives after you are done. I am interested on how the carb conversion turns out. I didn't have a big enough budget to do that or some kind of painless wiring harness for the FI so I just used the harness from one of the donor C/V. It doesn't look as pretty but it gets the job done on a small budget. Wish you was not so far from me I would like to see the engine after the conversion. On the trans how will that be done. Since the trans in the C/V is electronic is they a way to have a stand alone computer for it or will you use a manual trans or an old school auto like a C6 with a conversion plate on it? Can't wait to see your progress on it.![]()
crown vic ebay score
- fire truck
Re: crown vic ebay score
- fbomb100
yes ford and gm both have six speed autos I don't which one is better still have to make a bellhouseing so it can bolt up to the fe.fire truck wrote:
its all up in the air on what to do! I still got to lower the frame put the vic front sub on still not sure about the rear(ether a solid rear axle or a irs )and get the body work done frist!!
the allision would be cool
