lincoln mark VIII suspension
bryantracing460
Post by bryantracing460 »
Been looking at the crown vic swaps and wondered if a lincoln mark 8 front end would also work. If anyone could give me some measurements I could check. I have a 95 mark 8 w/ bad trans. :cry:
Jeremy
Drive It Like You Stole It.........NO FEAR!
69 F-100 swb 2wd 460 C-6. 86 F-150 super cab 2wd 302 AOD.85 Bronco 4wd 300 AOD.
http://www.myspace.com/bryantracing460
Don H
Re: lincoln mark VIII suspension
Post by Don H »
The front end from a 95 Mark VIII is a completely different animal. The Crown Vic is all one piece that bolts to the frame and as you probably saw the Mark VIII uses the frame for mounting the control arms and spring perches. Also the Mark VIII is narrower track width. Overall I would say no it won't work.
Don
bryantracing460
just my luck :(
Jeremy
fbomb100
Post by fbomb100 »
lincoln towncar from 2003 to 2010 are the same as cv,,,
you can make the 95 work ,,its just alot more work to do it then cv set up and the cv looks alot cleaner and better looking
marz68
Post by marz68 »
92-97 crown civ frames are the same lenght as your short bed. You may need to fab up some mounts but it will work just fine.
FoPAR
Post by FoPAR »
Do you have any pics of this done to a truck?
"FoPar" because I love Fords and Mopars so just call me FoPar... :D
carcrafter22
Post by carcrafter22 »
Yes the mark 8 IRS works great in the f100's even with the 03-08 CV front suspension.
67 F100 sc/sb 07 Crown Vic IFS, 94 Lincoln Mark 8 IRS, isuzu 3.9L diesel w/ HY35 & HX 52 compound turbos and 370cc custom injection pump,T56 6spd trans, 18" 07 dodge magnumm wheels, old air products A/C (for a 66 mustang LOL). 32 mpg's so far, around town
