Thanks, The engine is a .060 over 390 (401ci), reverse 105 (D4TE) block, KB flat-tops ( approx. 10.0/1 scr),Crank turned 10/10, oil-holes chamfered, mellings HV oil-pump and restrictors in the heads, Oil pressure is 25-30psi hot at idle & 55-60psi cruising. Cam is .484/510 lift, 270/280 duration, pushing Crane hi-intensity antipump-up liftersCaseys71 wrote:, Looks good! What are the specs. on that FE?
Brokenarrow wrote:Thanks, The engine is a .060 over 390 (401ci), reverse 105 (D4TE) block, KB flat-tops ( approx. 10.0/1 scr),Crank turned 10/10, oil-holes chamfered, mellings HV oil-pump and restrictors in the heads, Oil pressure is 25-30psi hot at idle & 55-60psi cruising. Cam is .484/510 lift, 270/280 duration, pushing Crane hi-intensity antipump-up liftersCaseys71 wrote:, Looks good! What are the specs. on that FE?
Heads are reworked D2s with larger (2.08 & 1.65) valves and hard seats. Streetmaster intake, Q-jet carb, flowtech headers w/ 2 1/2" thrush glasspacks.
thats far from a radical build!!! its more ilke a mild performance buildCaseys71 wrote:Brokenarrow wrote:Thanks, The engine is a .060 over 390 (401ci), reverse 105 (D4TE) block, KB flat-tops ( approx. 10.0/1 scr),Crank turned 10/10, oil-holes chamfered, mellings HV oil-pump and restrictors in the heads, Oil pressure is 25-30psi hot at idle & 55-60psi cruising. Cam is .484/510 lift, 270/280 duration, pushing Crane hi-intensity antipump-up liftersCaseys71 wrote:, Looks good! What are the specs. on that FE?
, Sounds like a pretty radical build!
