Front Brake Hose
19FORD67
Front Brake Hose
Post by 19FORD67 »
What do I need to watch out for when remove the flexible line to the front drum brakes on my '67? I assume I have to remove the hose at the bracket on the frame first.
Also, what's the best way to remove the hose from the frame bracket? I noticed on top there is an e-clip and on bottom the is a shim type keeper plate. Do I have to undo the metal line first so the hose can turn? :?
:fr:
'67 352 3spd 3.25 9" Custom Cab
'92 Mercury Cougar
http://www.fordification.com/galleries/ ... ?pos=-3222
Re: Front Brake Hose
remove the metal line from the rubber line at the bracket first. the the clip from the bracket. then the hose from the wheel cylinder.
19FORD67
Post by 19FORD67 »
Ok Fordman, thanks! I'm spent for the rest of the day, it's too dang hot out there for a fat boy like me!
:fr:
'92 Mercury Cougar
