I just bought a 69 f250 Ranger camper special, there is a light at lower left conner of the dashboard, and its on all the time once the truck starts. I don't have a owner's manual. can anyone help the answer what is this light for?
georgeiiv
light on the dash
- 72hiboy4x4
siunds like the emergency brake light.
try pulling up on the emergency brake pedal with oyour foot. that should shut off the light. if not the switch might need to be adjusted (or unplugged).
- granitestate68
re: light on the dash
Hi Georgeiiv,
First welcome to the site.
Follow this thread to get more info on your problem:
http://www.fordification.com/forum/viewtopic.php?t=3330
This sounds like a common problem with the brake system on our trucks. It's basically an imbalance between the front brakes and the rear brakes. Hence the light turns on.
Hope this helps you out.
Lee
Lee
http://www.fordification.com/galleries/ ... p?pos=-550
1996 F250 Slightly lifted 7.3L Diesel
1961 Falcon Ranchero 144 Inline 6
- 69F110
Thanks guys... .
