trailing arms
import600
trailing arms
Post by import600 »
Has anyone thought about trying to install trailing arms in the rear? it seems like it could be an easy install if the right parts were fabricated. what do you guys think. I was think it would make it a lot easier to lower my truck, and make drive like it were on rails.
any input would be excellent.
kyle
1971 F100 2wd swb 429 C6
rjewkes
Post by rjewkes »
are those anything like saftey tubes?
bluef250
re: trailing arms
Post by bluef250 »
I believe a 4 link setup could be fabricated and installed without much difficulty. :hmm: Cost to get the parts and do the work might be another story. Any maintenance cost savings probably would be eaten up in the assembly cost. The Ford setup needs very little maintenance. You just need to decide what you want to do with your truck. And what you want to have when you finished your project. If you want the truck slammed, the four link would be one way to accomplish the trick. Geometry could be made to match the stock spring setup. Currently, the rear axle rotates around the front leaf spring connection. A spring accomplishes the same thing whether it is a leaf, coil, or torsion or some other variation or highbred system. And the same with a shock. All the other components such as brakes, exhaust, fuel system would have to be considered to make sure you didn't create any problems along the way and the whole thing is safe. Personally, this type of project would not be something I would not want to do. :2cents:
flyboy2610
re: trailing arms
Post by flyboy2610 »
Given the geometry issues and safety concerns, I would have this job done by a professional suspension shop.
72hiboy4x4
Post by 72hiboy4x4 »
maybe it would be easier to set up a pre-engineered air bag system?
