I don't have to do this but a thought occured to me and I'm just curious.
When you convert to disc brakes, do you also need to upgrade the proportioning vavle too?
Converting to Disc Brakes
- bluef250
re: Converting to Disc Brakes
Yes, the drum brake system does not have a proportioning valve. You may need the master cylinder, proportioning valve, spindles, and I beams. Try to add a vacuum booster also. I think the best way is to find a complete donor truck. That way you don't have to search for hardware. See article for particulars - http://www.fordification.com/discbrakes01.htm
Thanks!!
