brake caliper pressure
- ccryder2011
i recently replaced the master cylinder and proportioning valve on my 67 f100 2wd shrt bed...it has 69-72 front brake disks installed....whats happening is when i brake everything works fine but the pressure in my driver side front caliper builds up after a stop (or two or three) and the brake drags...any ideas?
remember the key is to start what you finish....
....happy cruising...
1967 f-100 sb,mine
2007 subararu wrx,son#1
2003 mitsubishi eclipse,son#2
2007 mercedes E 350,wifes
1967 f-100 sb,mine
Re: brake caliper pressure
It could be anything from a kinked or otherwise restricted hose or line or an "O" ring for a caliper piston seal instead of a square cut seal. Make sure the are no residual pressure valves in the lines, as those would hold about 15 psi or so in that section of the system. Also check the caliper slides to see if there is binding.
1969 F-100 240 USFS
Flatbed, FS green, Offy C, EFI exh.
1961 Corvair monza
1990 GMC 1500
1989 Jeep Grand Wagoneer
1991 Ranger 4x4
2005 Toyota 4runner
2006 Dodge 1500
I am a vehicularly diverse person: I want everything!
1961 Corvair monza
1990 GMC 1500
1991 Ranger 4x4
2005 Toyota 4runner
2006 Dodge 1500
i agree. some sort of blockage so the fluid doesnt return properly.
- ccryder2011
fordman wrote:i agree. some sort of blockage so the fluid doesnt return properly.
my son got me new calipers for my b-day... all set thanks.....
1967 f-100 sb,mine
1967 f-100 sb,mine
FYI: Ford didn't install disc brakes on the F100 until '73, so if your F100 has them, it's been converted by a previous owner with '73-up parts.ccryder2011 wrote:i recently replaced the master cylinder and proportioning valve on my 67 f100 2wd shrt bed...it has 69-72 front brake disks installed....whats happening is when i brake everything works fine but the pressure in my driver side front caliper builds up after a stop (or two or three) and the brake drags...any ideas?
- ccryder2011
FORDification wrote:FYI: Ford didn't install disc brakes on the F100 until '73, so if your F100 has them, it's been converted by a previous owner with '73-up parts.ccryder2011 wrote:i recently replaced the master cylinder and proportioning valve on my 67 f100 2wd shrt bed...it has 69-72 front brake disks installed....whats happening is when i brake everything works fine but the pressure in my driver side front caliper builds up after a stop (or two or three) and the brake drags...any ideas?
figured that out when doing pads...thanks
1967 f-100 sb,mine
1967 f-100 sb,mine
ive found that when people replace disc brakes they let the caliper hang by the hose and it streches the hose and it frays the inside of the hose and it cant be seen, the pressure will push through but has a hard time returning making the front brakes drag untill the pressure can bleed its self off.
- ccryder2011
still building up pressure...replaced calipers,hoses,lines,proportioning valve,master cylinder,rear wheel cylinders,pads,shoes.....but still get pressure in the front brakes...wtf..??
1967 f-100 sb,mine
1967 f-100 sb,mine
new parts can be bad from day one. are you sure they gave you the right master cylinder? did you make sure the steel lines were clear?
- knightfire83
Push rod between the master cyl. and brake booster not adjusted correctly?
Differential valve plugged up? Brake light functional or on?
1970 Ford F250 4x4 ~ Sold.
You ARE using a disc-brake master cylinder, right? Drum brake master cylinders have residual pressure valves that will cause disc brakes to drag if used together.
- ccryder2011
THE MASTER CYLINDER I USED CAME WITH THE TRUCK NEW IN BOX...BUT I THINK IT WAS FOR A 67 WICH MEANS NO ITS NOT A DISK BREAK MASTER......THAT IS PROBABLY MY PROBLEM AS I WENT OUT FOR A CRUISE LAST NIGHT AND FOUND THAT I CAN RELIEVE THE PRESSURE RIGHT AT THE MASTER CYLINDER AND THE BRAKES ARE FINE FOR A WHILE....ANY FIXES OR DO I NEED NEW MASTER CYLINDER
1967 f-100 sb,mine
1967 f-100 sb,mine
(Better double-check that CAPS LOCK button on your keyboard...I think it's stuck!)
Yep, it sounds like you've installed a drum-brake master cylinder, and because they come with residual pressure valves that a disc-brake master cylinder doesn't have (for the disc circuit), it's maintaining pressure in the front circuit. I'd be willing to bet that replacing the master cylinder with the proper piece will take care of your problem.
- ccryder2011
thanks i think your right i will get new master cylinder and see whats up...sorry bout the caps lock my son used comp last...
thanks , cris
thanks , cris
1967 f-100 sb,mine
1967 f-100 sb,mine
- ccryder2011
finally got all the right parts and the brakes work like new....thanks to all that helped....!
1967 f-100 sb,mine
1967 f-100 sb,mine
