brake and steering question
J LEE
Post by J LEE »
If using DJM drop beams on a 68 f100 will the power disc front brake setup and power steering setup from a dentside f250 bolt up or do I need to keep looking?
Re: brake and steering question
that would be determined by the king pin size on the djm beams. and the spindles you are going to use. if the beams coem with spindles then you will have to ask them which disc brake rotors fit thier spindles.
J LEE
Post by J LEE »
If I'm not mistaken theirs dont come with spindles or king pins anymore, probably because of the different sizes. with that being said the swap is possible correct? Also i would like to use a flaming river or Ididit tilt steering column when I change to the power steering setup and put the shifter for the C6 on the floor has anyone here done this? Any advice on this swap? Thanks
