interchange for front hubs
goldwing44
Post by goldwing44 »
I have a 71 F-100 1/2 ton and 1 of the front wheel hubs is bad(bearing race turns) are there any years that well interchange with this truck,oh yes stock brakes. :?
dean
70_F100
Re: interchange for front hubs
Post by 70_F100 »
Honestly, before I would spend the money on replacing that hub, I'd seriously consider a disc brake swap from a dentside.
goldwing44
I have the disc brake setup to swap as far as the front end parts dont have the master cylc or power booster or lines and I need to do this asap as it's at a local JC there is a class working on it
Dean
68-72 with the same size brake shoes. i think they will be pretty much the same size unless it was a heavy duty rated truck or a F250 then the shoes should all be the same size. the 67 brake drum has narrower brakes. i have one of the standard front hubs i can ship out first thing tomorrow.
goldwing44
thanks fordman I found one agine thank you
dean
good deal.
