2 wd- 4 wd conversion
Loosie65
Post by Loosie65 »
I have a 71 SWB 2 wheel drive. How hard would it be to convert it to 4 wheel drive. I might have access to a 77 full size long box. Would the suspension parts bolt up? Or am I looking at a lot of cutting and welding???
1971ford
Re: 2 wd- 4 wd conversion
Post by 1971ford »
Tons of threads on this. Look in the 4x4 section you will see a few.
To sum things up... If you do not have good welding/cutting skills, and don't have tons of time then don't try converting your 2wd chassis to 4wd. The two frames are nothing alike and you will have a lot of fabrication to do. Everyone is goign to tell you to swap your body onto a 4x4 chassis. You can put it on the dentside chassis, that is your best bet. It won't bolt directly on though. SteveC just put his bump body on a dent 4x4, maybe message him.
-Ryan
1982 flareside
Post by 1982 flareside »
Your frame is set up for 4wd. But it is hard
Jeremy
1971 Ford F250 camper special 360 T18(old model) 4 speed 4.11 gears 2wd with 1969 doghouse soon to be daily driver FRANKENFORD
1982 Ford F150 flareside 300 T18(new model) 4 speed 4.11 gears 4wd Daily driver
Some people say my truck is ugly and all i say is "Beauty is in the eyes of the beholder.
no the 2wd frames are different than the 4wd frames. because of the location of the crossmembers and the boxing of the frame sides from the frotn crossmember back to the radius arms.
1971ford
Post by 1971ford »
1982 flareside wrote:Your frame is set up for 4wd. But it is hard
Nope, totally different frames. A lot of fabrication involved.
-Ryan
Redcap
Post by Redcap »
Incorrect.
'60s Dodge trucks were set up like that, but not our Fords.
